1 - 8 of 8 Posts
Yeah it'll work,is the computer still in the car? If it is, you should still have the pulg that goes into the tranny on the car just plug it back in. If not just order an aftermarket lock-up switch, oh yeah that 200r4 isnt electronic
they make a kit to convert them from electronic to a vacuum switch to control the over drive and lock up converter...dont run it with out the overdrive hooked up it will burn up
painless sells the kit
Super Smasher
[snapback]3535627[/snapback]​
cool...is a 700r4 the same ? just the lockup is controlled?
Yes,but the T.V. cable controls shifts on both trannys, and it has to be hooked up right or youll burn up the transmission .
B&M or TCI sells the torque converter lock-up swich kit.
1 - 8 of 8 Posts
