1 - 15 of 15 Posts
I got a cutlass with chevy 305 wrap frame 3/8 in the back 3/16 in front two inch extension on a-arm ten batteries adex one inch port to 3/4 check valve how should i plumb it and what springs do you guys recomend and gear? Single pump it to the front! :biggrin:
did you just purchase this set-up or a car with it? does the set up already have a gear or do you have a lot of parts you are going to plumb on up? It,ll help me know what your working with.
Pumps are put together allready 3/4 check striaght to y block up front and top of the y the slow down the adex. with number six fitting on the y.
4 1/2 MBQ's for the front end, im kind of leary about the whole 3/16 in the front, thats not much for reinforcement. and marz #11 gear in the piston pump
sing it for what it,s worth, the reinforcements don,t sound bad for single pump, try some 4 tons just to get the fluid warm LOL post some pics once you get it going.
Originally posted by ElChingon@Sep 19 2007, 07:45 PM~8828445
4 TONS WILL DO THE JOB,,IT DEPENDS ON WHAT IS GOING TO BE A SINGLE OR DOUBLE!!
go with a nice 3 ton or 3.5 4ton more bounce to stiff unless broke in bye a double or somthing!
the 3 to 3 1/2 tons are gonna be a lil too light for the v-8 motor thats in the car. they will bottom out by the 3rd or 4th lick he needs to go either 4 ton or 4 1/2 precompressed coils. or could always try a 3 1/2 ton precompressed coil with a mini coil inside of them but i still think the 3 1/2 tons are gonna be too soft for it
3.5 or 3 ton is what i prefer and have always worked for me, single pump 10 batts full frame v8 55 inches,no weight, with the reds white coils 5 1/2 turns deep cups! but like i said a used set of 4 1/2 really really broke in do ok too! even pro hopper mach threes do better, hell in the front of are dancers we use 2 tons and they still do 45-50, think about it v8 full frame= heavy, right? ok now stock sinlge pump no piston has to lift a v8 a full frame and still compress a 4 1/2 ton coil? youll burn a motor before you compress a 4 1/2 but like i said,if a 4 1/2 works for you then cool but a 3 or 3 1/2 works for me ,just going off the physics!
4 1/2 tons broken in by a big body first works great
3/16 is plenty strong front or back. 1/4 just adds weight and if it's in the front it isn't helping your hop.
1 - 15 of 15 Posts
