:roflmao: :roflmao: :roflmao: IMPALA OR CAPRICE OR ROADMASTER REAR END SHOULD FIT HOMIE :biggrin:Originally posted by biggeazy-e@Oct 17 2007, 08:16 PM~9026632
94 Cadillac Fleetwood Brougham :cheesy:
howd you "tweak" your rear end?????Originally posted by NLRA@Oct 18 2007, 06:27 PM~9033307
Thanks alot homie the one on my big body is tweaked and I need to replace it.
No...Impala had rear disc. Conversion is possible, but not a direct swap.Originally posted by biggeazy-e+Oct 17 2007, 11:16 PM~9026632-->Also '95 and '96.94 Cadillac Fleetwood Brougham :cheesy:
[/b]
<!--QuoteBegin-RAGALAC@Oct 17 2007, 11:31 PM~9026752
:roflmao: :roflmao: :roflmao:Originally posted by blueouija@Oct 24 2007, 10:15 AM~9072356
meth :dunno:
Roadmaster and caprice rear-ends are not the same they are longer! I found out the hard way. I got an axle out of a roadmaster and put it under my fleetwood and it was a longer on both sides. I had to pu standard offset wheels on it and it would still rub if you droped one side. I hated the standards on there and thats one of the reaseons I sold my fleetwood. Also the ABS is different the Roadmaster has one plug and the fleetwood has two. (your ABS and Traction Control will no longer work)Originally posted by RAGALAC@Oct 17 2007, 11:31 PM~9026752
Depending on the year, the ABS and Traction Control are the sameOriginally posted by juiced 64@Dec 9 2007, 09:37 PM~9412859
Good Luck! Hopefully you read this B4 buying one.
