Got a 94 caddy.with lt1 wsn I ho to start it it drags like timing is of so I checkd it and it eus just fine so I put a new starter and nee red top optima battery and still does the same as lso sume times it seems like staryet sticks I use a screw driver to turn it over and it will start with the key for a couple days wut do u guys think it could be fellas?
That is not the problem it is pulling a lot of power somewhere wen it is being started or sum times the starter will not turn untilled I use a screwdriver to tap selinoid then will turn
