1 - 3 of 3 Posts
well I parked it about 20 minutes before i went out and started to go somewhere and that fucker didn't wanna turn on
it just clicks and clicks if u hold it......
is it my starter that went of?
its in a 1994 cadillac fleetwood with the lt1
i think the selonoid and starter might be good because it kinda wants to start but not enough and it smoked a lil bit like coming from the starter might be the cable that is loose???
disconnect the battery ... make sure your starter wire is not grounded to your headers ...
other wise you might have a short in the wiring .. maybe bad diode in alternator .. and if back feeding ..or other wise that alternator is dying .. less them optimum volts..
charge the battery and clean all them connections while your at it to be safe
1 - 3 of 3 Posts
