1 - 10 of 10 Posts
I plan to build a 98-99 town car as my next show ride. I was wondering if anyone has some input on the town cars like weaknesses in the frame or what I should look out for. I havent purchased one yet, but have my eye out now that my ride is sold.
I notice the 98-99s dont have full digitals dash's like my 92 does.
I prefer the 98-99's over the 2000 new bodys.. or did they change the body in 2001?
thanks
i seen some people change the spindles an duppers. don't know why,but would like to know also.
people change the arms from i think 91 and lower TCs because that style is prefered, for extending and reinforcing, the newer arms are the tubular wishbone looking 1s
I seen one with Caddi A-arms on it :0
PEOPLE SWAP OUT SPINDLES AND BRAKE ASSEMBLIES TO FIT 14'S OR 13'S. I CHOSE A 91 TC SWAP. WITH THE STOCK BRAKES YOU HAVE TO GRIND AND ROLL WITH ADAPTERS. WHICH IS A BIG NO-NO. THE 91 A ARMS ARE THE SAME 98 -01. I THINK THE BODY CHANGED IN 02. COULD BE WRONG. AS FOR THE A- ARMS. YOU CAN SWAP SOME 80'S TC BUT YOU NEED TO SWAP THE A-ARM MOUNTS TOO. THERE WAS A THREAD WHERE SOMEONE REINFORCED THE TUBE ONES. IT CAN BE DONE JUST MOST PEOPLE I GUESS DONT TRY IT. IM LOOKING TO JUICE MINES ALSO. IVE LEARNED ALOT HERE ON LIL.
thanks
first off yes, 98-06 towncars do not come with a full digital dash. second, the 98-02 body styles are exactly the same and was changed in '03. i had a lifted 98. the only thing u gotta worry about on the frame is the upper control arms. either extend them and reinforce really well or do as i did and swap the uppers, towers, and spindles from a 90 or older TC. if u dont do the swap, then u also will need the 91-94 spindles.
but the frames are fine on these cars. they get tricky 03+.
good luck
EnViUs
good luck
good info right there :biggrin:
could someone explain why the spindles need to be swapped out to run 14 or 13s??
I have a 92 and I added a 1/4 spacers to run 13's on it. Never had any problems with it. Is that bad to do that?
thanks
1 - 10 of 10 Posts
