1 - 12 of 12 Posts
Originally posted by teamde@Oct 3 2007, 07:17 PM~8927010
u sure...... what do i have to change to get the 14inch wire wheels to wrk ???????
Just the spindle, rotor, and caliper. A 14 will bolt on without any grinding.
but does the 94 have the speed sensor hole that wudnt affect anuthing? and then the bolt for the caliper
The 94's have ABS too, but i don't know if the plug is the same of not.
Originally posted by teamde@Oct 3 2007, 07:52 PM~8927198
crown victoira doesnt have of of those ....... are u meanin the caliper
No. The back of the rotor has knotches in it and there is a sensor that counts those, its a wire thet goes down to the spindle. I did a 2001 town car and it had this.
i check today ..the crown victoria doesnt have it ... i had a cop car ... i am sayin there is a bolt that conects the break line to the calieper do i need to change that
It was the same on the one i did.
Originally posted by teamde@Oct 3 2007, 09:05 PM~8927767
ok thanks spidle rotor caliper bolt to caliper which year 94 spindle
If yetti says it will work then you know where the topic is... :biggrin:
I wasn't sure but its a good notion when D4L says it will work.
and on the ABS sensor, you can remove the whole sensor like it did and replace it with the factory one.
http://www.layitlow.com/forums/index.php?s...ic=364484&st=0#
1 - 12 of 12 Posts
