1 - 12 of 12 Posts
למה אני &#1506
ive replace the idle control valve the fuel pressure regulator and cleaned the MAF sensor, it has a loss of power, runs very sluggish and has random power boosts.....im going nutz please help
G
check all vacums lines,and if u removed the mass air flow sensor check the porcelain fitting to see if it cracked
למה אני &#1506
what porcelain fitting? and yes the check engine light is on
whats the codes
Face Puncher
running lean... leaking intake manifold gaskets. If I'm right, have them replace the intake with a new unit that has the aluminum water manifold up front.
למה אני &#1506
already did that, i had to replace right when i bawt the car 2 months ago :cool: i went to autozone and had it tested today, they said its my fuel pressure sensor its on the fuel pump and they said i have to replace the whole unit...$248 :(
Have you checked fuel pump pressure at the injector rail with the car running in park and at highway speeds? This way you can verify if its the sensor or the pump.
can always do a current ramp test on the fuel pump to check and see if is getting weak... but to do that you will need a lab scope with an amp clamp or a mutlimeter with an amp clamp..
למה אני &#1506
i already changed the one on the fuel rail, thanks thou....there telling me its the one on the fuel pump
1 - 12 of 12 Posts
