got a 99 trans am with 111,000 miles. I just checked the antifreeze and it has brown balls it looks like.. ayone knows why? could this be rust? what can i do to fix this? Thanks
Flush the heater core while your at it just to be on the safe side. If it has stop leek it can clog.
Puro GUERRERO Compas
Originally posted by Ragtop Ted@Jan 17 2010, 09:25 PM~16320540
Flush your cooling system.  You can buy a kit to do it at your local auto parts store.
X2 FLUSH IT N CHECK IT, IF IT NEED S ANOTHER FLUSH DO IT AGAIN TO GET ALL THAT SHIT OUT :puffin:
i dont feel tardy
then put stop leak back in it too replace whatever they were using it to fix the first time
drain the system and put fresh in since you havent said any thing else is a problem
such as no heat or overheating just drain and replace
X's 2
