That's your clutch engaging and disengaging. It's a normal function but if it happens too often then you have problems. Could be low refrigerant. you need to get a refrigerant gauge set or take it to a shop and have them check it. Do you have cold air at all?Originally posted by ROBERTO G@Nov 18 2008, 03:01 PM~12193513
how do you know when its fucked up?
on my car the front part, which looks like a triangle spins, stop, spin, stops ,and so on
is it supposed to do that?
If you are low or have no refrigerant then your description is normal.Originally posted by ROBERTO G@Nov 18 2008, 04:15 PM~12194360
so it works...
yeah it happens in about a min or less intervals. and no it dosent have any refrigerant. i was just testing out the new blower motor
x2-if its clear out clutch wont engage,thought my caddy had busted compressor till i charged it,at first it wouldnt kick on at all,then did what your describing,then stayed on finally when i got coolant close to full :cheesy:Originally posted by hotrodhomi@Nov 19 2008, 10:59 AM~12199529
if it has no coolant it wont send power to compressor/clutch-if it does have coolant start with fuse then relay then sensor ect..... could also be faulty switch in climate controls ,busted vacuum line and so on-start simple then look into pricy shit,or just roll windows down :biggrin:Originally posted by Gold86@Sep 23 2010, 06:36 PM~18644888
ok, the wires are not getting power to the compressor.
Any idead where to start?
if it has no COOLANT is for the engine.
fixed.![]()
oh hell lol-you know what i meant lol-i have a habit of sayin that by accident :yessad:Originally posted by kandylac@Sep 28 2010, 08:25 PM~18685479
fixed.
