i went through the "whole clean the check valves out thing" and it still dumps with the valve shut. it almost sounds as if the motor or the pump head is turning backwards, but not by motor force, by pressure from the fluid. should i take the check valves out and clean them again. there was nothing in them to begin with.
my second question is:
would it make any difference if the power wire from the switch box was hooked up to 12 volts instead of 24? i put it on 24 volts and it doesnt work. i think that might have been to the ground on the second batt. it has to go on the + of the second batt right?
thanks for any helpful replys.
