1 - 5 of 5 Posts
o k isnt it better if mounting pumps in the air instead of actually on the trunk, they should be on an angle with the motor facing down and the backing plates facing up so that all oil gets to the pumphead???? if you had the backing plates facing down and motors facing up, not as much oil would get to the pumphead right???? please let me know if i am correct. thanks!!!
if you mount them with the motor facing downwards i sugesst you get a motorseal kit from prohopper, then you cant get oil in the motor even if you blow the o-ring.
if you mount it with the motor facing upwards you need to connect a piece of pipe to the pumphead so it can suck up the juice from the bottom so you wont risk to get air in your system...
yeah thats true, never mount them to the trunk floor, it might buckle your quarters too...
o hell no i wouldnt mount em to the actual floor i just meant i want them in the mid air of the trunk instead just on racks but sitting right on the floor ya know. thanks for the info!!!
1 - 5 of 5 Posts
