Check the fuse by the driver's door. I assume you have stock rearend gears. There's 3 abs sensors, one in each front wheel and one in the center of the rear differential. If you recently did brakes, maybe the sensors in front have debris on them or a bad connection. pull the rear sensor out too and clean it off(it's on the top of the diff and it's just one 10mm bolt that holds it).
that shit sucks i know from exp. that if u changed brake pads or shoes ,it'll go off ,somthin with the sensors,take it 2 a brake shop,they'll get it off
