1 - 17 of 17 Posts
in 80's full size cars- impalas, rwd caddys, deltas, caprices..... if you remove the a/c unit, do you lose the heat too????
just making sure.
also, is the a/c unit the only thing i will need to disconnect from the dash/computer?????
thanks....
eazy :cool:
SPELL CHECK
I'm not sure I completely understand what you're attempting to remove. But, if you remove the compressor, condensor, evaporator, etc. you will still have heat as long as you do not remove the blower motor and the wiring that goes to it. :cool:
and where is that located?????
im talking about the big ass (plastic) bulge on the pass side firewall, that the a/c shit is connected to.....
Originally posted by cashmoneyspeed@Sep 19 2005, 12:54 PM~3842959
The blower motor and box for it will be inside the car on the passenger side behind the dash.
so i can keep the heat and get rid of the a/c?
i have another dash i can look at, but it's in a crate, and i dont want to open it....
Triple OG
ac unit controlls the cold air.
heater core controlls the heat.
blower motor blows them in your face.
yes, you will still have heat if you remove the a/c. Just don't remove the blower motor (yes, the buldge on the firewall)
the heater core is usually in the dash and it is connected to the engine by 2 hoses. Coolant circulates and the heater core is bacally a small radiator.
Thats why the engine has to heat up a little before the heat starts working.
in simple terms... you can get rid of the a/c but youll still have the buldge. i pulled out my heater box, and no longer have ac or heater or a blower motor.
:( ive gotta make a plate so i cant see into the engine bay anymore
maybe plexi glass woohoo :cheesy:
Originally posted by cashmoneyspeed@Sep 19 2005, 09:18 PM~3846451
Are you trying to install something in the dash that you're looking to take it out? or maybe some weight reduction?
no, actually, the way i shouldve worded the ost should've been "molded firewall, can i keep the heater..."
im going back and forth on this one...... the problem is, the a/c works fine on this car, but, i have another project i would definately do this on..... but, both?????
maybe....... :dunno:
Discussion Starter · #13 ·
Originally posted by concrete@Sep 22 2005, 08:27 PM~3867775
are you asking if you should keep the vents if you don't take out the heater?
nah, if i get rid of the heater(bulge) i wont have use of the vents right?????
Triple OG
the heater isn't the buldge. Thats the blower moter. (fan)
The heater is in the dash behind the radio. You won't see it without taking off the dash board.
But to answer your question...if you get rid of the buldge (blower motor) you won't really need the vents.
You can plug your heater core if you don't want any heat.
Discussion Starter · #15 ·
alright, so just bear with me while i get this straight.....
no heater core, no heat
no blower motor, no heat
no ac parts, no ac
no blower motor, no ac
no blower motor, no vents, ac, no heat......
Triple OG
no ac parts, no ac
yes.
The heater and a/c are 2 completely different things.
the a/c creates cold air.
the heater creates hot air.
the blower motor (fan) just blows them at you through the vents.
If you get rid of the both the heater and the a/c you will have no use for the vents.
If you keep one of them...(heat or a/c) you will need the vents still.
Discussion Starter · #17 ·
Originally posted by concrete@Sep 23 2005, 12:05 AM~3869309
yes.
alright.....
vents=blower motor
without one, i dont need/have the other.....
hmmm, is this what i ireally want....... :biggrin:
1 - 17 of 17 Posts
