Originally posted by aircraft_dump_man@Dec 4 2003, 03:35 AM
boucin89 you don't know shit so don't come in hear tryin to tell me something about accumulators
piston accumulators are the best those bladder one's
bust because metal pieces can puncture them it's like using a ballon and to you can't use a bladder type to make your car hop higher why don't you go hang out with bubba sparxx are something and go travel some lone dark dusty roads idiot
In the post that I responded to, I was countering the fact that you said that "piston accumulators are the only real accumulators." In that case, that is an incorrect statement. And from your previous post, seeing that you're the self-proclaimed reigning "King of Accumulators," I'm sure you agree that that WAS an incorrect statement.
Whether or not piston types are the BEST is just your opinion. If you had said that the first time I would not have responded because I would never argue someone's opinion.
If your only rationale for piston-types being better is because diaphragm-types "bust" when "metal pieces" puncture them, you should come up with a new one. There shouldn't be any metal shavings in your system. It's almost like telling a doctor that a Sawzall is better for amputating someone's leg 'cause it cuts faster. :uh:
I don't have bladder type accumulators, I have diaphragm. And I also never mentioned anything about using an accumulator to make a car hop higher.
And what does hanging out with Bubba Sparxx and travelling down long dusty roads have to do with accumulators?
And last but not least, since whether or not I'm an idiot is just your opinion, again, I won't even try to argue with you on that.
