1 - 2 of 2 Posts
Quick question, Is it safe to grind a lil bit off the holes on the adaptors to make`em fit on another car? Had the adaptors on a Regal and wanted to put`em on a Crown Victoria but they wouldn`t fit unless i grind a little bit to open up the holes like 1/8 of an inch, Is it safe to do or should i just order other adaptors?
NO, do not shave any part of the adapters. They're cheap enough, just buy a set that fits rather than risk your car/life/etc...... Bolt pattern on the Regal is 5 x 4.75". Bolt pattern on your Crown Vic is 5 x 4.5". A set of universal 5 lug (15 hole) adapters would allow you to use them on both cars and also have a 5 x 5" patten.
1 - 2 of 2 Posts
