I have a L.A. series kit from prohopper with a adex. im putting all the fittings together now. On the adex there is a pressure port and a return port on the same side. on the other side there is a brake port. the way i am running it is with the slowdown tee'ed off of the main flow. From the slow down valve, to my adex and back to the resevoir. My question is do i use the pressure and the return or can i use the pressure to the brake. Does it make any different's? If there is a different's please let me know the best way to hook this up. Thanks
