I want to get 2 12s and an amp but dont want to spend much i was looking at this deal on amazon for 2 12s kenwood and an 1800 watt amp for $230 but is it worth it and will i get some good bass out of it here is the link
http://www.amazon.com/KENWOOD-KFC-W3012-Su...6352530&sr=1-44
what about the RE AUDIO REX12D4 12" Subwoofer, Incredible rejuvenating sound up to 2000 watts power handling for $60 each are they better and sound louder than the kenwood and what amp would go with these would any of these work. and i dont understand why does it say sounds up to 2000 watts is that how many watts each have. thanks in advance
Lanzar MXA282 Max Pro 4000-Watt 2-Channel High-Power Mosfet Amplifier
http://www.amazon.com/Lanzar-MXA282-4000-W...66352443&sr=1-9
Kenwood KAC-9104D 1800-Watt Max Power 1 ohm Capability Class D Mono Power Amplifier with Variable LPF
http://www.amazon.com/Kenwood-KAC-9104D-18...66352443&sr=1-1
PYLE PLAM3000 3000 Watts 4 Channel Bridgeable Amplifier
http://www.amazon.com/PLAM3000-Watts-Chann...6352443&sr=1-24
Out of those two subs the kenwoods have a higher rms than the re's. The kenwoods are 400 rms and the re's are 175 rms. And the amps I'd go with the kenwood also. It's a little bit more reliable then the other two and a bit better and cleaner power than either of the others.
there 175 rms but i dont understand why it says 2000 watt handling. i think ill go with the kenwood package for 230 any mor input from anyone
get 2 se 12 ..call the guys at www.db-r.com ask for a sundown sae 1200
thats gonna give u real 1500watts and good woofers that can take it...
hey i have 2 12 se on my 88 ls and they hit supper hard am running both in a sealed box the only thing i took out was the low pass so it wont rattle the trunk go on e-bay you'll find them cheap there :biggrin:
