1 - 15 of 15 Posts
Whats the best # gear for my car..its a 85 chevy camaro i got 48 volts....i thik i got one of the smallest rockford gears now....but i want more bounce!!!!
I would go with the #9 head. Some people might say a #7 because of the voltage but, in my old s10 a #9 worked better.
#9 MARZ or #7, both are good :cool:
get marzocchi pumpheads...
#6 = low volume, high pressure.
#13 = higher volume, lower pressure.
even # are steel pumpheads
odd # are italian alloy type pumphead.
now a high #pumphead needs more volts to perform the best.
with 48 volts i would go with a #9 pumphead cuz that gets up pretty fast...
Originally posted by lowlow90@Dec 29 2003, 03:25 AM
bigger fittings and one hose to a y with # 11
He is only running 48 volts so it would be slow and drain the batteries fast. Go with the 9.
i like #8 gears ...it has good speed at low voltage....and learn how ta hit the switch..u b all good
2GUNZ
None it is a 85 Camaro. Check your frame first, but I would go with a #9 Marz, that seems to be the happy medium.
1 - 15 of 15 Posts
