1 - 20 of 40 Posts
I love hearing "PAPA"
OK lets keep this clean, no BS stuff or haters. Unless you want a good bitch slapping.
The H-series valve has a bore size of 1/2 inch/12.7 mm, with a Cv value of 2.6. In its standard form the valve is fabricated from 316 stainless steel, and is rated for operation at pressures up to 6,000 PSIG (414 barg). The metal to metal sealing of the new valve also meets the firesafe requirements of ISO 10497 (the international equivalent to the API 607 and BS6755 Part 2 standards).
Providing leak-free performance, our double ferrule compression tube fittings find diverse application in oil and gases, petrochemical/ chemical processing, aerospace and defense, pulp and paper, research laboratories. In addition, it is also used in cryogenic and semiconductor, shipbuilding, power generation and heavy industries. Available in a variety of configuration and sizes, our tube fittings fulfill the need for leak proof gas and fluid containment. There are various types the tube fittings available:
Parker offers pumps for hydraulic, fuel, oil, fluid transfer, lubrication and aerospace applications. Parker pumps are available for open or closed loop systems. Pumps from Parker range from industrial and mobile hydraulic pumps, miniature, electric motor driven, fuel and aerospace hydraulic system pumps and airframe pumps for boost and fluid transfer, lubrication and scavenging, ejector and jet pumps.
more to follow,
Check Valve, High Pressure
High pressure check valve for aerospace applications, male or female AN ports, low cracking pressure, 316SST construction., 3000 psi or 6000 psi max operating pressures available.
Relief valve, needed for those stock high pressure pumps.
i like it...
i have been looking at this sort of stuff the last 3 or 4 years, but here in australia its hard to get a hold of this stuff unless you are in the industry.....
keep it coming.... ;)
Hydraulic Pumps
AeroControlex manufactures a variety of fixed displacement hydraulic pumps for the aircraft and aerospace industries. These hydraulic pumps are designed for pressure up to 5,000 psi, and are rated
for high altitude performance.
Typical Specification
Flow:
1.89 gpm
Pressure:
750 psi
Speed:
8,000 rpm
Weight:
5.6 lbs.
Power:
28 V dc
Typical Applications
Dash 8
ATR 42/72
Saab 340
Dornier D328
Embraer EMB120
Macis High Pressure and Control Technology has developed a line of hydraulic control products to assure safe and easy plumbing through 20,000 psi. These flow control valves, check valves, switch valves, safety valves, throttle valves, adjust valve, hydraulic actuators, filter valves, exhaust valves and pilot valves are engineered to the highest standards of repeatable quality.
Hydraulic Control components use a compact coned-and-threaded connection which permits the larger bore sizes and increase flow rates common in this pressure class. Hydraulic Control valves are available in 1/4”, 3/8”, and 3/4” I.D. tubing sizes and several patterns to satisfy widely varied requirements.
Macis high pressure products have been widely used in several industrial domains such as marine, off-shore, aerospace, heavy industries, oil, natural gas, chemical engineering and industrial automation and control.
up to 20,000 PSI
I'm going to start using uncommon parts for my setups, do my part to end the mindset that you only have 2 options, and parts are best identified by distributor name rather than specifications.
great stuff Tony.
theres so much stuff out there, i doubt any 1 person could try it all out in one lifetime. some of its plain ugly, but some of it has a lot of potential to look good in ANY trunk.
plus ANYTHING aircraft or aerospace is 1,000,000 times better engineered that tailgate pumps. ;)
i bet lowrider hydraulics would progress more and more if people would stop filling their trunks with weight and trying to hop 200 inches.
more to follow,
who has a line on these slow downs?
Parker Aerospace.
im using some from the same line on a custom machined setup im working on for a homie. ;)
Originally posted by TATTOO-76@Mar 22 2010, 04:26 PM~16963143
Parker Aerospace.
so we just call and order them? These companies don't usually sell to the public.
i have an open account with a local Parker store. :cheesy:
Parker Aerospace.
76 is STILL ALWAYS INTO SOMETHIN!!! I'd love to see that :thumbsup: :thumbsup:
1 - 20 of 40 Posts
