1 - 11 of 11 Posts
I saw these on the Gauge Mag. Site. What kind of app. would you use those on? Air cylinders? :confused:
yup so the air cylinder can flex there is a plate of flexible metal or some shit in the center that flexes when you hit the road for better ride air
Presumably these are not for air spring-set ups. I thought that air springs improve the ride over coil springs with the standard air suspension set-up.
Are air cylinders a bit too solid, like hydraulic rams, and these accumulators are like the gas-filled ones used on hydraulic set-ups?
Originally posted by air280@Nov 13 2003, 02:43 AM
no flexible stuff in there, it's just that air can compress and they allow more volume [so more compression] to allow some travel in the cylinder
are you saying there is no plate in the center or just not something flexible
Thanks :cool: .
Originally posted by joebomber52+Nov 14 2003, 02:12 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (joebomber52 @ Nov 14 2003, 02:12 AM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--PSI@Nov 13 2003, 12:01 PM
there is nothing in there felxable at all.....just a place for air to sit.
but there is still a plate in the center right[/b][/quote]
yes :)
..and you don't need them with bags, just a way to try and give some ride with cylinders
does anyone have this one their set-up (well those that are using air-cylinders that is), and if so, how do they 'ride'?
1 - 11 of 11 Posts
