1 - 5 of 5 Posts
So I am running 4 dominator 2500 bags on a car that weighs about 2200 pounds in theory they do what they should more air it goes higher less air it goes lower but the ride quality is about a 3 on a scale of 1-10.
I am looking for any suggestions for bags that are softer and are about the same diameter or smaller then the dominators so hopefully they will be the same mounting dimensions. The travel can also be reduced i never run them up to full stroke usually only about 3-5 inches depending on road conditions
I'd recommend SS-6 bags. Direct replacement for the Dominator 2500lb bags. The SS-6 bags have the same bolt-pattern, non-ballooning design (Dominators expand outward when adding psi), offers better clearance, 2.7" compressed, 11" max height, better ride and the only bag on the market with internal bumpstops. Problem fixed.
I got slambags with a P3 system on my 64 and they seem to do well
1 - 5 of 5 Posts
