1 - 16 of 16 Posts
Banned
did you do it?
i say you can go either way
need alot of re-inforcment if you want to 3 wheel with hydros
due to batteries, pumps and rack weight
if you want air you will need a little trimming on the frame not much
not noticable either
you will have less weight
on the chassis
with the air suspension
can have a more confined set up with air, than with pumps and batteries for hydroz
the only hydro set up worth getting wold be a 4 pump 4 dump set up for indivudual corner control
with air individual control versus front back control is about $130 dollars
in valves
air suspension:
valves for individual corner control can be found for about $300
a decent tank $60
plumbing $100
wiring$50
p.switch $50
and 4 air bags for about 200-600 firestone being around 200 bucks
i have used firestones for years
have a set on the front of y car that have been on it since the first set up 10 years ago and they have been through constant abuse of around 300 psi
about $100 for the metal to make the brackets
then all you have to worry about is a compressor
1 - 16 of 16 Posts
