have a air leak cant hear it or see it with soap on all fitting..no bubbles so any sug on where it mite be coming from....is it possible to be coming from dump valve .....valves r new
i got my own valves out nowOriginally posted by dirtylooks@Sep 6 2005, 08:19 PM~3764349
they r dan valves and they air cylinders by eai
Are you sure that they are not nickel plated?Originally posted by blznnp@Sep 6 2005, 08:24 PM~3764863
chrome fittings? not sure i have ever seen those, i only use brass fittings, if everything is fine, and you don't see any bubbles, you do have a good amount of soap in the water right? then i would say its the valves or maybe somewhere in the line there is a small pin hole, but if that was the case then when you aired up one corner or the front or back, then only that part would drop. do you loose psi at the tank or at one of the corners?
i kinda paused for a second when i read that too...Originally posted by 216RIDER@Sep 6 2005, 09:56 PM~3765198
nickel is the 2nd step in chrome plating.Originally posted by b_diddy1@Sep 6 2005, 11:18 PM~3765912
I've never caressed another mans genataliaOriginally posted by CuttieBuddie@Sep 6 2005, 11:28 PM~3765976
i was just like, DAMN, what HASNT he done already...
-qs
