air ride doing away with flexi lines?
1 reading
1.2K views 5 replies 4 participants last post by  badcayne
#1 ·
Ok a few questions for you air ride guys, I am using stainless/ptfe flexi leader lines to my bags and they go into the bottom of the bag. My bags at the top are hard mounted to my chassis and I want to clean up the system and reduce connections.
could I flip the bag and just run a hard line to the top of the bag? or is this going to cause problems with water filling the bag in time and not draining away? I do have a filter/water trap on my setup between compressor and tank but I doubt if all the water is taken out completely.
thanks
Rob
#2 ·
i run 200 psi set up ,i have a 250 psi wilkerson water trap between compressor and tank , i have also 1/2 SMC water traps placed in the front of the car inline with the valves closed to front bags ,one for each front bags, and there is water when i open them..
#3 ·
Almost all the setups I've seen, the air fitting is on top. The few exceptions are those that have special mounting circumstances. The proper place for a water trap is between the tank and valves. Compressed air is hot. When it cools, it condenses (condensation/water) in the tank. A water trap between comp and tank cant stop that.
