1 - 8 of 8 Posts
hey guys...i have a 1977 lincoln continental mark v and i wanted to get a basic air ride system fbss with a limited budget.. i have 1200 us and i have some one willing to do teh install for free. does anbody have any ideas? from where i should get it, and what should i get... i was thinking 3/8 lines and valves cause i dont want my wheel well banging off my 20's. and maybe a 1 5 gallon tank and i probably 1 compressor if i could get away it. neways, thanks for anyones input.
I would use a minimum of two 5 gallon tanks for that lincoln of yours and highly recommend an additional compressor. 3/8 valves and lines will be fine. :cool:
Originally posted by cutlass kid2@Oct 11 2007, 02:30 PM~8977535
thansk sixoneforlife...do you know where i could get a kit with 2 5 gallon tanks and two compressors for 1200 us
not sure, i pieced my setup together many years ago.
I have some used valves for sale.
2x Viair 380c 200 PSI Compressors
1x 7 Gallon Hoosier 8 Port Tank
8x Asco 300 PSI 3/8" Valves
1x 200 PSI Pressure Switch
2x 40 Amp Viair Relays
1x 10 Switch Box - You Choose Color [black,red,blue,clear]
2x Viair Dual Needle 220 PSI lighted gauges
1x 4 Gauge AGU Fuse Holder
50 Feet x 3/8" DOT Air Line
50 Feet x 1/8" DOT Gauge line
4x 7" or 6" 200 PSI Slam Specialties Air Bags
1 x Complete ALKON DOT Fitting Pack [includes 1/8" PTC For Gauges]
$1177 to your door.
I can give you parts you need to make your own mounts.
$1177 to your door.
:0
Originally posted by phatz@Oct 17 2007, 04:28 PM~9023568
Whats up mr.bubble
Got those tanks installed today, found them direct from Firestone. ;)
I had them base coat/clear coated body color.
1 - 8 of 8 Posts
