INFO STALKER
I know this is late. I’ve been away.
You got a lot of learning ahead of you ! Each valve needs a power and ground. If you mount the valves to metal, you can ground it right there. Two valves per corner. add a tee between the valves to go to the bag.
found this link on wiring the comps.
https://www.avsontheweb.com/content/instruction/2_TO_4_COMP_WIRING.jpg
one thing I didn’t see was water traps, you NEED water traps! Buy push-to-connect (PTC) fittings. Use tape not dope on the threaded fittings. use quality DOT approved air brake line, it has nylon string woven into the air line for extra strength. Don’t kink the line. Add grommets whenever going through sheet metal. there is a lot more to know also. Follow some mini trucking forums For more help.
