1 - 8 of 8 Posts
over it
What about the rears? If they are disk brakes on the back I believe they are going to rub on them also. My boys 95 did at least. Just remember to put new brake pads in at all four corners because that will put the brake calipers outboard as far as they will go. If you don't do this and have a very close fit and your pads are worn when you put new pads in you may have a clearance problem. If the rear is drum you should be good.
1 - 8 of 8 Posts
