Aluminum or Steel Block
454 Views 6 Replies 4 Participants Last post by  switchs66
Which is the better choice performance wise and dependability for a double pump hopper? I am debating whether to just replace my current 3/4 aluminum block or buy two new steel blocks.
ARE STEEL BLOCK BETTER AND FLOW OR IS IT JUST BECUES OF THE
WEIGHT.
I KNOW THAT IN ENG. PARTS ALUM. HAS BETTER FLOW.
WEIGHT.
weight,stronger material,not as soft as aluminum...
G
WEIGHT.
material has nothing to do with flow.
the reason aluminum engine componants flow better is because they are made with larger ports, it has nothing to do with the material.
:thumbsup: THANK'S FOR THE INFO.
is there a specific brand that you guys are buying? and what size 1/2, 3/4, 1 inch?
