1 - 11 of 11 Posts
Originally posted by chavezthagreat@Sep 10 2006, 07:24 PM~6144028
if its the back tires mine do it too the ball joints are bad and the tie rod end might be going too
its front pass.and back driver,but ill ck it thanx homie
my 88 has real bad issues on the rear the ball joints are banging and knockin and then there is this squeaking i cant fix it yet so i just turn up the radio and grease it every couple a days its killing my tires though
your probably driving with a negative camber most of the time since theres is know way to know exaclty where it has to sit for a perfect alingnment you will probably buy awhole lotta tires
knock offs are hell on wheel bearings they actually present tourqe to your spindels as if to be prying up on it causing negative camer the when its up the problem reverses with too much positive camber
1 - 11 of 11 Posts
