Doesn’t it make you feel frustrated when you have your Amazon Fire TV Stick Have Sound Issues and doesn’t support audios or just mutes the playback sound? The problem can be rectified by applying some easy methods. If after trying all the mentioned steps, the problem keeps on reoccurring, then you must instantly get in touch with the technical executive at Amazon Firestick Support 1-855-438-6011 fir guided assistance. • Turn off the TV, and switch it back again after a minute.• Ensure that the software settings are up to date.• Make sure that Firestick is not mute by looking at the AC receiver(it should be turned on)• Check whether the HDMI cables are connected tightly. Read More: - Amazon Firestick Customer Care
