1 - 10 of 10 Posts
I HAVE THE 1507 HOOKED UP TO 2 HX2 15'S.EVERY ONCE IN A WHILE IT WILL START MAKING POP SOUND(NO MUSIC),LIKE THE RCA'S ARE SENDING A BAD SIGNAL OR A BAD SET OF JACKS?ANY BODY EVER HAVE THIS PROBLEM?THANKS IN ADVANCE.
Try running a different RCA cable just for testing purposes and see if it still does it. Also check the ground and all your connections something may just have gotten loose and need a little tightening.
what did I tell you when u asked about getting this amp???I said the only thing its good for is the 4guage gold connectors.
:roflmao: :roflmao: :roflmao:your wright!but this amp was fine and im sure it would be a cheap fix.this amp does put out some nice power.
i am gonna try switching the cables,but i think the internal rca's are loose and getting a bad ground.ill let ya know,thanks
IT WAS THE RCA'S(CHEAP WALMART SHIT).THANKS FOR YOU HELP.
WHY DIDNT YOU LIKE THIS AMP?
:cool: Glad it was just a simple fix.
1 - 10 of 10 Posts
