1 - 11 of 11 Posts
my mtx amp's remote wire is wired to the dome light fuse and its always on which fuse should I wire it to to make it turn off with my car because its overheating
2GUNZ
Yeah that is what I was wondering.
If you have a stock head unit run the remote wire to you accessory wire on the back of the radio. Thats the radio that gets 12v when you turn the key on. And check out that over heating problem, cuz thats not caused just by the amp being on you probably have the amped bridged to a low ohm load.
does it have a power antenna lead, wheni was using the factory infinity cd player in my old chrysler i hooked the remote lead to it, factory gm radios have a power antenna lead, assuming you have a cutlass
1 - 11 of 11 Posts
