Ok another idea, I do some of my best thinking after a few 12oz’s
Just a thought to kick around some, for some of the sharp minds here on LIL.
Real fast, no drawings yet:
You run 8-10 batteries. Say you have a plate holding down your batteries, this plate is in two pieces. You bolt each battery cable to the outer part of this plate. The center part of this plate has contacts. There is a second plate that sits inside of this plate, that then connects each of the batteries together. The plate allows the batteries to sit in parallel voltage. By moving or flipping this plate around, you then have series voltage to any set amount, like 96 volts to the front and 24 for the back.
The benefits:
One charger charges them all, then like quick disconnects, you flip the plate over for the hopping voltage. The plate is also used as the battery hold down.
Comments???
The benefits:
Comments???
