just curious if anyonwes got a good pic of their accurates all wired up? what guage wire did ya use for the trigger jumpers to each? also does it matter which post ya put the trigger on or doenst matter?
Thanks in advance
Trevor
Thanks in advance
Trevor
Here is a pic of mine
And yes, it matters. You want to use the S terminal of the noids, not the I.
yeah just on the top posts, i have sum 10 that i was gonne use, will it hurt to overkill it? also does it matter which of the top posts i use?
Trevor
Trevor
Overkill is always better. As far as the top posts, I mentioned this on my last post for you but ya must not of seen it. There are two posts, one has an S, the other an I. You want to use the S post, NOT the I post otherwise bad things will happen :biggrin:
Yes it matters us the post with the little (s) under it like homie said.
How many batteries do you have and how many noids to each side? :cool: :cool:
sorry to re post but i lost that thread. i really appreciate ya postin it again, thanks alot! im runnin 2 bays 24v in each, i got 3 noids per pump
Trevor
