1 - 12 of 12 Posts
Polypack seals in there cylinders instead of the o rings & back up washers?
No... Let us know how it works out... :uh:
Originally posted by Naughty T+Oct 29 2003, 08:36 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Naughty T @ Oct 29 2003, 08:36 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--2drWood@Oct 29 2003, 11:31 PM
No... Let us know how it works out... :uh:[/b][/quote]
I know they work great..........I just always tell people about them but it seems like they never heard of them
They are used for industrial hydro applications. The more pressure that hits them the more they expand against the outer walls makin g them blowproof
I've been wanting someone else to try them & see if they had the same great luck with them that I had.
yes, and use u-cup types.
these hold up to higher pressure, more abuse and have less leak down.
:biggrin: ,
cc
Originally posted by Cruz_Campos+Oct 29 2003, 08:40 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Cruz_Campos @ Oct 29 2003, 08:40 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--2drWood@Oct 29 2003, 08:31 PM
yes, and use u-cup seals.
:biggrin: ,
cc[/b][/quote]
I think those are basically the same concept.............write or wrong, not sure, some peeps probably call them diferent names
Originally posted by 2drWood+Oct 29 2003, 08:43 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (2drWood @ Oct 29 2003, 08:43 PM)</td></tr><tr><td id='QUOTE'>
:biggrin: ,
cc
I think those are basically the same concept.............write or wrong, not sure, some peeps probably call them diferent names[/b][/quote]
if you go to an industrial hydro shop yes.
cc
Originally posted by Cruz_Campos+Oct 29 2003, 09:08 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Cruz_Campos @ Oct 29 2003, 09:08 PM)</td></tr><tr><td id='QUOTE'>
:biggrin: ,
cc
cc[/b][/quote]
Glad someone has heard/tried them.
I swear anytime I get cylinders from now on I'm throwin out the o rings & plastic shit from the get go & using these. :)
I love hearing "PAPA"
Are these looking like seals ?
If so..
I think Pallies or Ottos used to sell a cylinder called BLACKS. They came stock on in the cylinders, but those seals were a real pain to r/r. Once you got the cylinder in the bore, (which was another pain), the shaft was tight as hell. You has to stomp on them to get them to move in the bore , even with lube.
Nice looking cylinders,
I had to make a tool just to get them on. But I only used it once. I sold the cylinders because I thought they were too tight to hop on. They had to be the best cylinders I ever had for not leaking.
I didn't have any probs getting mine together.
The only thing I could complain about was until they got broke in I guess they had a little creeking noise, like a rubber bushing skweaking
THEY ARE CALLED PACKING SEALS, THEY WORK GOOD FOR USING THE SYSTEM PRESSURE TO SEAL ON BUT THEY STILL LEAK A BIT, YOU NEED A PACKING AT THE TOP AND A O-RING ON THE BOTTOM SLOTS
The u-cup seals are the best thing going. I haven't had an actual "failure" in years. But I'm sure it also helps that I change my seals every year.
1 - 12 of 12 Posts
