1 - 3 of 3 Posts
I just got 1 with the 1600 watt Kenwood amp.....
just curious if any1 has this sub? If so, what is it like?
One look at the new KFC-XW1100DVC Kenwood Excelon subwoofer tells you that it's unconventional, and one listen will tell you that the competition won?t stand a chance. To create this radical new sub, Kenwood has re-thought and re-engineered nearly every aspect of subwoofer design. Incorporating a 2-layer Tornado PBO advanced fiber and non-pressed pulp cone, Multi-Bias Magnetic Circuit with dual voice coils, a huge 2-piece magnet, dual spiders, a 2-piece cast aluminum frame, and many other features, the KFC-XW1100DVC will make other subs run home crying to their mommies.
SPEAKER FEATURES
Cone: 11" Tornado-Type 2-Layer Micro-Weave PBO Advanced Fiber and Non-Pressed Pulp
Dual Conex Dampers
Dual Vented Voice Coils: Long-Throw
Frame: 2-Piece Cast Aluminum
Frequency Response: 36Hz - 1kHz
Impedance: 3 ohms + 3 ohms
Magnet Weight: 2-Piece, 109.4 oz (6.8 lb)
Mounting Depth: 8.5"
One-Piece Rubber Surround and Gasket: 1" Wide, Extra-Thick
Power Handling: 1,600 Watts
Protection Fuse: Built-In 25A
Sensitivity: 79dB
Speaker Connectors: Banana Plug-Compatible, Screw-Lock Design
Vented Pole Piece: with Internal Heat Sink Fins
THIELE-SMALL PARAMETERS
DC Resistance (Re): 2.6 ohms + 2.6 ohms
Electrical Q Factor (Qes): 1.0
Force Factor (Bl): 14.5Tm
Mechanical Q Factor (Qms): 4.06
Moving Mass (Mms): 7.05 oz.
Peak Excursion (Xmax): 14mm
Resonant Frequency (Fs): 36Hz
Total Q Factor (Qts): 0.81
Voice Coil Diameter (d): 2.56"
Volume Acoustic Compliance (Vas): 0.777 cu. ft./22 liters
2GUNZ
You know the problem with that white speck on top of Chicken Shit, well that white speck is Chicken Shit too.
Don't think so bro. Kenwood, I wouldn't give that sub to my hated enemies.
To create this radical new sub, Kenwood has re-thought and re-engineered nearly every aspect of subwoofer design....
everytime a company have a new speaker/sub on the market they tell you the same thing
:uh: :uh: :uh: :uh: :uh:
1 - 3 of 3 Posts
