1 - 12 of 12 Posts
i was browsing around and i stumbled on this i was wondering if anyone out there has seen it before and if so is it any good
Character:
A mono amplifier
Feature
*Amplifier type: Class T full range digital power amplifier
Technology by Tripath. IC chip TA3020
*Double side glass Epoxy, 4 oz circuit PCB.
*See through window designed.
*Subwoofer frequency adjust-able.
*Built in subsonic filter.
*Power limited.
*Protections: Speaker shorts, Reverse battery,
and Thermal.
*Sunon cooling fan.
*Gold plated: RCA audio, Speaker and connectors.
Specifications
*1 Channel car amplifier
*0.1% THD output power: 1200watts @4 ohms /
1500watts @2 ohms
2000watts maximum
*Frequency response: 20Hz~300Hz / +-2dB
*Subwoofer phase adjustment 0¢X~180¢X
*Sensitivity: 250mV~4V
*Subwoofer frequency: 30Hz~300Hz / 24dB/oct
*Subsonic filter: 30Hz Q=7.5
*Signal to noise ratio: >85dB.
*Idling current: 2A
*Power fuse rating: 140A
*Dimension: 420mm*240mm*50mm/ L*D*H
yeah i personally thought it was a piece of shit i just wanted to see if anyone would prove me wrong
1 - 12 of 12 Posts
