1 - 16 of 16 Posts
i found thess prices are they any good
SMC 3/8" valves 34.99
Drooz(never heard of these)3/8" valves 34.99
adjustable pressure switch square D 24.99
50' 1/2" airline 34.99
10 switch prewired box 49.99
firestone 2600 bags 69.99 each
8 1/2" port 12 gal tank 74.99
whats the difference lift and lowered wise between the 2500 and the 2600 firestone bags?
if anyone can tell me if these are good prices it would really help me out
Not bad prices,The lift difference is about and inch or so maybe less.Plus the 2600lb. being stronger.
Face Puncher
2500's have a little less lift than the 2600's..
the real difference is the diameter..
the 2600's lift more weight with less pressure..
which means it will have a better ride too..
Originally posted by BeerMonkeY@Nov 1 2003, 06:34 PM
so for my burban i would wnat the 2600 all around.does it make a huge difference if i use different brand vavles for up and down
2600's all the way around!
Smc valves will do just fine.Stay away from spool valves!They're garbage!
they're more "heavy duty". call fbi, they'll hook you up. either 3/8 or 1/2" valves. and either 2500, 2600, or any type of slam bag. they got the best prices i found then on top of that, they still hooked me up with another 2-3 hundred off.
Discussion Starter · #15 ·
thats where i got the prices from. i will most likely get mostly everything from there. only thing they dont have are front bag mounts for my year suburban. but i called him and he said he would have some made for sale by spring. so i might wait untill then, if i can
yeah i def go with suicide and if you need some tech advice on bags s10forum.com has the best bag forum ive ever seen.
1 - 16 of 16 Posts
