Associated Battery Charger
2079 Views 22 Replies 12 Participants Last post by  Dumps
Anyone have one like this will it charge batteries in series like 96 volts or only 12 volts but up to 10 batteries in parallel? These are the specs listed
Model 6065 Parallel Charger - - - - Charges 1 to 10 batteries, in parallel, in less than 24 hours. UL Listed. 16 charge rates for precise charging. Patened multi-diode rectifer with deep reserve capacity.
Charger Specifications: D.C. output - 30A, 14.9V ~ A.C. Input - 108-132 V, 7.5A, 60Hz ~ Charging Cap.:Up to 12 V ~ Charge Rates: 16 ~ Volt Meter: 11-17V ~ D.C. Leads: 6ft ~ D.C. Leads: 6.5ft. ~ Dimensions: 16"X19"X16" ~ Weight: 40lbs
1 - 20 of 23 Posts
I believe thats the one Hoppos sells for about $426. If that is the one, they said it takes a week to get it.
why does it show batterys in parallel on the cover?
Brent, Check this one out.... I've had this one for years and it's great... This one will do them series so you don't have to undo any wiring.... It's a little slow on it's trickle charge but the charge lasts a long time...
http://www.menintools.com/battery/6082.html
DC Output:6amp/0-158volts
AC Input:120 volts/13amps/60HZ
Charging capacity:1 to 60 cells
Charge rates:adjustable
AM-Meter:0-6amps
DC leads:8ft.
AC cord:6.5ft
Anti-spark delay timer protection for safety during hook-up
Full wave silicon rectifier Isolated transformer for safety
Circuit breaker protection
Easy-to-remove clamps
Heavy-duty design for safe operation and quality performance
Made in USA
Shipping dimensions:(HxLxW)22"x17"x13"
Weight:45 lbs.
thats the one i want right there but 430.00 oUCH
Yeah it's a little steep but worth it. You won't mind the cost years from now and you still have it... :cool:
a pic from last year.....
yeah i think ill just get a schumacher that does 6 at a time for 145.00
thats the one i have but i have the 10 sets of cables. havent used it yet, dont have the batts yet. i was wondering how you fine tune it? i didnt get the book with mine.
i got mines for 200 with the 10 sets of cables on a rack, only a year old.
you talking about the 6082 or the 6065?
heres a link for the schumaker se10-72 for 42.95 plus shipping...i paid 159 for mine shipped and it came in 3 days!
http://www.batteryservice.com/products_fin...lNumber=SE-1072
6080a 72 volt charger used but in good shape for 150.00 shipped what do you think?
ASSOCIATED BATTERY
MAINTENANCE EQUIPMENT
This series charger with higher output voltage charges new batteries and rejuvenates sulfated batteries. Fully charges six maintenance-free batteries at a time. Has an isolated transformer for better safety, plus circuit breaker protection. Includes five charging leads.
DC Output:6amp/106volts
AC Input:120 volts/8amps/60HZ
Charging capacity:1 to 36 cells
Charge rates:64
AM-Meter:0-6amps
DC leads:8ft.
AC cord:6.5ft
UL listed Circuit breaker protection
Mounts on wall or bench
Made in USA
Weight:40 lbs.
thats what i have. i have the se 1072. it wors good. i let my shit charge for about 8 hours. i hook it to the first pos and the last neg in my trunk. i disconnect the ground tho. :biggrin:
Ordering is fast, easy and secure. Place your order before 10:00 am, Monday - Friday and you'll recieve it that same day!
how is that possible?
i had a schumacher i lent it out and well its toast now
was told by many not to use the 10 amp on the schumaker charger....... expencive fix
ASSOCIATED BATTERY
Charge rates:64
AM-Meter:0-6amps
DC leads:8ft.
AC cord:6.5ft
Made in USA
Weight:40 lbs.
Brent that one looks like one a friend of mine had when he had a juiced ride.. let me check with him if that is the one.... it sounds good though and has some good features.. :cool:
i picked this one up for 150.00
Where did you buy it at? :cool:
found it on ebay
Originally posted by Mr Impala@Sep 8 2005, 06:16 PM~3778200
found it on ebay
Such a good deal, you had to take it to bed with you :biggrin:
1 - 20 of 23 Posts
