i hadnt taken my knockoffs off my monte till this month and noticed they didnt have any weights on the back like other wheels ive owned.do they balance wire wheels?my car had a little shake ever since i put them on.
Originally posted by baggedout81@Jan 16 2010, 01:25 PM~16310450
Have the put stick on weight's on.
Putting on the hammer on lead weight's scratches up the lip in turn will allow rust to start under the chrome after time.This is putting the weight's on the back of the wheel
:wow: :nono: all my 13x7-72 spoke (stamped)daytons dont shake at any speed.....Originally posted by RollinX151@Jan 16 2010, 02:30 PM~16310480
There are places that won't do it but you should balance them....just have them use the stick on weights on the back so you can have the front lip clean...the car will still shake if your on the highway reaching 70...
If the car is shaking, you probably have a wheel/tire or suspension problem.Originally posted by 83monte509@Jan 16 2010, 04:37 PM~16311576
more often than not,what is it that could be loose.i dont wanna take it to tire joint cuz these guys are ridiculous on prices
If there is a problem, you will feel it more up front.Originally posted by dj kurse 1@Jan 16 2010, 07:16 PM~16312691
i've been told that the rear do not need balancing at all and only up front do?
That is because when they are only balanced on one side with the stick on weights like you are supposed to do on custom wheels, it is a STATIC balance. And a static balance is just half ass, because you are only correcting half the problem.Originally posted by RollinX151@Jan 17 2010, 02:12 PM~16317248
No I don't, I had it balanced with weights on both sides like regular and the car was rolling perfect. I had asked to have it balanced with stick on weights on the back only and now like at 70-80 it shakes a bit, not alot though. Thats why its low and slow...lol..gotta give up a luxury to have a luxury
x2Originally posted by baggedout81@Jan 16 2010, 04:25 PM~16310450
Originally posted by alexg1200@Jan 18 2010, 05:09 PM~16327879
My Z's on 5.20's werenot balanced at the time of mouting. Dorve it a few time and speeds over 45 my Monte shook bad... After I had the wheels balanced it resolved the problem. Balancing your wheels and tires is a must. Just my 2 cents if it mean anything.
