you can still clear over it. if it is a base coat you dont need another base coat.Originally posted by Day Day@Jan 11 2004, 02:40 PM
well the whole rreason behind this question is my friedns got some paint and i dont know if its single stage or not also i wanna clear it because im flakin the hell out of my truck i have silver base and he has the blue i want but i dont if its single stage or not so i was wonderin even if its single stage could i just use it like a base coat and clear over it???
Is it dupont chromabase or nason or????Originally posted by Day Day@Jan 12 2004, 02:26 PM
im doing 2 colors silver n blue... i have the silver now i need blue the limco was silver base but the blue is a dupont but im not sure if its single stage...
is this the dupont candy ? if not your putting a base coat over another base coat, thasts what sounds wierd even if it is a single stage it just means clear is added to mixture.Originally posted by Day Day@Jan 12 2004, 12:26 PM
you are 2 toning it. okay mix the flake in the paint it will still be flaked out then clear over the whole truck make sure you put the same amount of flake in both colors.Originally posted by Day Day@Jan 13 2004, 04:19 PM
ill look on the dupont can whenever i get a chance by the way my truck will be blue on top silver on bottom
yesOriginally posted by Day Day@Jan 14 2004, 01:11 PM
but will it be ok to clear over a single stage paint
DING DING DING!!! O dogg has the right answer!!! :thumbsup:Originally posted by 64@Jan 15 2004, 10:02 PM
I would say let it dry, wet sand it then clear over it
