I had a couple of questions. hope yall can help me here they go.
i want a hard hitting system that ya can hear me coming from blocks way. I have a 2003 Impala LS I plan to use a line converter to an EQ then to the Amp. I don't really wanna change the radio or any other componets i want to leave it alone. so here are my questions.
1- Should i get 3-10's or 2-12's?
2-When i start putting componets together i need to look at the RMS and not peak power right.
3-I want to buy one amp the parallel wire the subs to the amp for example: ROCKFORD FOSGATE AMP 1050S which puts out 1050 watts RMS x 1 at 4 ohms bridged which will be parallel wired to 3-10s Audiobahn AW1006Q FlameQ 10 that handle 900 watts RMS would that work good would i need to buy separate amp and hook them up?
4-I want to put them in a custom box with a fiderglass molded face (where you mount the subs) do i need to divide the box or could i just make a big box without any in walls eparating the subs. i plan to port the box by the way.
5-What would happen if i make the box bigger the the recommended cubic feet requirment would that mess up the sound or help it?
This would be my first install so any help would be helpful. Thanks
