1 - 3 of 3 Posts
I'M DOING MY FIRST SET ON A CUTTY AND I WANT TO KNOW WHAT'S THE BEST WAY TO WELD THE BATT RACK TO THE FRAME. DO ANY ONE HAVE ANY PIC'S :cool:
i use 2x2 square tubing.. weld to bottom of rack and to side of frame. just some other advise. make sure you space your rack off the trunk, say about 1/2 inch to that the weight of the rack is on the frame and not the trunk floor
If you don't weld the rack to the frame then yuor trunk will start coming apart at the seams.I would weld the box tubing to the frame and then bolt the rack to the stands that way you can still remove the rack without any cutting or grinding.
1 - 3 of 3 Posts
