1 - 3 of 3 Posts
I have 8 group 31 commerial grade that i bought from a company local here they have 1190 cca and a 210 reserve, draw back is that they do not have the ability to remove a cap to fill the cells these are the only brand ive used because my rack was designed around them, i'm on my second set.
What im wondering is if any of the other 31's have the ability to add water or not mine are not to be opened found out the hard way opened it up and then cap wouldn't seal again.
if you need to keep adding 'distilled' water you are charging them to rapidly and its boiling up. set your charge rate at a lower amperage to avoid this.
if you use the batteries heavily.the heat and chemical reaction will cause some evaporation..so top in them off from time to time is necesary...
1 - 3 of 3 Posts
