I have an 86 buick regal and my question is that my battery light stays on and when like the radio is off it is not as bright. But when i turn it on it gets darker and it gets lighter and then darker ass the music basses. what could this be if u guys have ne suggestions please reply. thanks
battery is going dead?? or maybe your alt is about to go....cuz if your lights dim when your base hits it means your car don't have enough power..so it sounds like your bat/alt isn't puttin out the power like it should be..
yea, get it tested at a shop, and they'll test both the battery and the alternator...i just did on monday. my alternator was fine but apparently one of the cells on my battery was dried out. so i replaced it...good luk :cool: !
Super Triple Double OG OG
na, time to replace both.....
Class Act
if i kicked on suddenly its your alternator check you batt voltage it should be above 12 volts if it went down its you alt
