1 - 9 of 9 Posts
its about 30 degrese out and i hit a switch for a second to see if the batts were still up and they were pettery much dead. so i started charging them up one at a time with a 12 volt cherger at 2 amps. according the gauge on the charger it isent all the way full after 2 day on the charger. so does it need more time or are they getting shot. they are 1050 cca and are about 2 years old..any thoughts
well they are some old batteries to begin with..and me personally i dont know what king of affect the cold weather has on them when charging and discharging... u may want to try chargin them on a lil higher amperage setting
Originally posted by budgetblueoval@Jan 8 2009, 09:38 PM~12647536
u think 2 years is old?
a battery can only handle so much discharge and recharging... 2yrs is a lil old....u might want to take the batteries down and have them charged and load tested....but for a 2 am charge it usually takes me about a day to charge 1 battery..dependin on how low it got
also the cold will slow the charge down a bit if your using an automatic charger just let it go till it turns itself off
Originally posted by Marquez@Jan 10 2009, 06:39 AM~12660977
Get Optima yellow tops, they last 4-ever!
who sells them cheap
Originally posted by nyd40cal@Jan 10 2009, 10:31 PM~12663028
nobody!! :biggrin:
Check out batteriesareus.com
they got decent prices at least for me cause here in sweden they cost like 350$ a piece
1 - 9 of 9 Posts
