1 - 5 of 5 Posts
GLASSHOUSE RIDER
Which are some nice ones to use up front in the engine compartment, with the engines battery? For a Cutlass.
GLASSHOUSE RIDER
Thanks. :cool: By any chance do you know of any that are Chrome or polished?
BATTERY CLAMPS/TERMINALS
Power distribution starts at the battery and Rockford Fosgate has a wide range of battery clamps. Solid brass with unique clamping methods, Rockford delivers the power with the least amount of voltage drop and resistance.
BATTERY CLAMPS/TERMINALS - TYPE RF
Designed with the competitor in mind, Rockford's multi-output TYPE RF battery clamp utilizes patented X-Grip technology for the tightest connection to the battery post. Designed to handle up to the 2/0 AWG Super-Flex power and ground cable along with the complete range of Rockford Fosgate high performance power cables.
Details CPPSBC1
HPP Platinim Plated Competition Dual Output, Single Input Battery Clamp, w/ X-Grip Technology.
BATTERY CLAMPS/TERMINALS - POWER
New thread-on style battery clamps are the ultimate design for a connection to the battery. Just twist it on and hook up the wires. By using expansion modules, several different combinations of connections can be achieved. Up to four modules can be added for a total of twelve connections. Available in HPP Platinum Plating for maximum conductivity. All battery clamps come with plastic protective housings.
Details CPBCMAX1
HPP Platinum Plated MAXI fused Battery Clamp - Positive.
Details CPPBCAGU1
HPP Platinum Plated AGU fused Battery Clamp - Positive.
Details CPPBCEMF1
Expansion module for all Fused battery clamps - (2) 4 AWG or (2) 8 AWG connections.
Details CPPBCEMT1
Expansion module for CPBCTO battery clamps - (1) 1/0 AWG and (2) 4 AWG connections.
Details CPPBCEMT2
Expansion module for CPBCTO battery clamps - (3) 4 AWG or 8 AWG connections.
Details CPPBCML1
HPP Platinum Plated Mini-ANL fused Battery Clamp - Positive.
Details CPPBCTON
Thread on style with (1) 1/0 AWG and (2) 4 AWG directional connections - Negative.
Details CPPBCTOP
Thread on style with (1) 1/0 AWG and (2) 4 AWG directional connections - Positive.
Details CPPBCWN
HPP Platinum Plated Wing Style Clamp - Negative.
Details CPPBCWP
HPP Platinum Plated Wing Style Clamp - Positive.
Details RP8215
Gold Plated Side mount to post style battery terminal.
BATTERY CLAMPS/TERMINALS - PUNCH
Gold plated, high quality solid brass battery clamps with tough Rockford quality.
Details CPGBC24N
Gold Plated Battery Clamp with (2) 4 AWG input / outputs - Negative. Includes plastic cover.
Details CPGBC24P
Gold Plated Battery Clamp with (2) 4 AWG input / outputs - Positive. Includes plastic cover.
Details CPSMB
Gold Plated GM side mount to bolt battery terminal
Details CPSMBL
Gold Plated GM side mount to bolt battery terminal - long thread
1 - 5 of 5 Posts
