1 - 20 of 21 Posts
how the hell did i bend a cylinder only had them a month and it just goes up/down
they were showtime comp 8in just ordered some new 8in. from cce but how can i keep it from happenning again
what do you mean up/down the cylinder goes up and then goes straight down with out dumping or what
well if you ordered them from CCE you fucked up what color is the cylinder
no i ment that the set up only does up/down but i bent a cylinder and want to know why it happened a how/if i can stop it from happenning again the ones i have are crome from showtime the ones the shop here ordered are crome from cce
i dont see how you bent a cylinder up front i have had showtime cylinders the ones
i use are yellow they are the competetion cylinders no problems ;)
wus your truck 4wd and you made it 2wd ? Wus it the front right cylinder that bent ?
I think cause you left it 4wd thats wut is messing things up, how did you do the front suspension wit the 4wd ? and wut size cylinders did you use up front ? The 4wd frame only has bout 5 inches of travel so you should not be using any thing bigger than a 6 inch cylinder
shit i got 8" showtimes all the way around.The fats (a little biger than medi) with black top feed cases.hope they hold up.
but i always here bad things abour cce strokes.maybes its just there cheap ones though. but my 2 fav cylinders are the old school reds and the brass colored pro hoppers.
got them in there and 8in is just right on an s-10 i''ll get pics of it asap
i just bent one how does that happen?
Discussion Starter · #13 ·
The guy at the shop here in town swears by cce and has a toyota mini and a regal
(g-body) with all cce i have all showtime but bent one of the cylenders now it leaks so he ordered a new set of cce comp cylenders and said i won't have a problem with those
By not purchasing CCE cylinders, now you gone have another headache on your hands, ask anyone :roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao:
Discussion Starter · #15 ·
ok then what cylinders should i use and does anybody have a duel dump setup for a showtime pump for sale
dont sweat what everyone is sayn about cce i have had a pair of 8's on the front of my car for over 3 years and ive only rebuilt one side once
CCE has had a bad rap on there cylinders,I personally never ran them but i wont experiment,supposedly they are making them better now but i have heard nothing but good shit about showtime's cyl. :biggrin:
Discussion Starter · #19 ·
ok well the guy at the shop is doing a warrenty swap from my showtime becase he did the install so it didnt cost anything for me now i am looking for a duel dump assemble if anybody has one for sale for a showtime pump and thank you for the info
Just wanted to put my 02¢ in. I was GIVEN some brand-new never-pushed CCE 8s. I had them in for about a week. left them lifted, NOT LOCKED overnight. Next thing I knew they were leaking. Then as I was hopping around a little bit one day, I bent the hell outta one. (Damn shallow spring cups).
Anyway, lesson learned. I bought some Red's... I hope these are going to work a little better.
YL.
1 - 20 of 21 Posts
