if ur running a single piston what has been reccommend to most is the marz #11 if ur doing a double piston then youd want #9's as far as the back pumps are concerned i run marz #9 its not a preference its just what i had 2 of laying around. the distance between hose and cylinder is less then 4 feet the gear size is plenty fast enough. u could even go down a notch if u wanted to. but #9's in ur back pumps are just fine even on 36 volts my cars ass end jumps off the ground and i am also running only 8 batteries. plus if u run 36 to ur back less wear and tear on ur motors as well
from what the picture shows of ur piston pump it looks like u have ur block sideways so that the pressure line is on its side. if i was u since changing gears and/or seals in these pumps come often i would just put the block the right way upward and use a swivel cup fitting to a 90 degree elbow as well as a swivel cup fitting for the return line at ur block so that if u need to take the pump out u can just undo the swivel off ur 90 as well as the return line and the pump comes right out without having to undo all the other shit
im going to be running almost the same setup (without all the chrome) and from the experience ive had i would say the #11 with at least 8 batts to the front if you plan to hop.
